Community Member
Password for make call
I have installed call manager 4.1(3)sr3c, and the phone ip make logon across Extension Mobility, how i can to do that when i make any call the phone get a password.
Re: Password for make call
we provide FAC and CMC to address that, you can configure one or both depending on your needs
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi Java,
Is it possible to tweak the FAC timer?
Meaning, after being prompted for the FAC code, the timeout timer would want to be longer.
Thanks.
Community Member
Well, I found the asnwer to my own question.
The user enters the authorization code. The system then either waits for the FAC Timer (T302/ or interdigit timer) to expire (default 15 seconds) or for the user to press the "#" key.
Note: Since the FAC timer affects T302 timer, bear in mind that if you adjust this timer to permit more time for FAC input, it extends the time for normal calls as well.
Cheers!
245
