07-11-2007 10:16 AM - edited 03-14-2019 10:29 PM
does anybody know how you can reset or find the following passwords for callmanager. I have a client asking for this information and we only have the admin password for the system.
DC directory
SQL sa password
Can these be reset if lost without complete re install
07-11-2007 10:39 AM
There is an utility that you can use to reset these passwords. The utility is called adminutility. Here is a link explaining how to use it. http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
Be sure to run this after hours as it stops services.
Please rate helpfull posts
07-11-2007 12:55 PM
To Change DC Directory Password:
Please follow the instructions in the following document (attached for your reference):
How to Change the DC Directory Password
To change the SQL SA
Account Password you need to do the following:
1) Select Start > Programs, Microsoft SQL Server > Enterprise Manager.
2) Follow the tree down until you see Security > Logins.
3) Highlight Logins in the left window.
4) You will see all the accounts configured in SQL.
5) Highlight the SA account and hit the right button.
6) Choose Properties in the window that appears.
7) The password should be on the General tab.
8) Change the Password and either press OK or Apply.
Please follow the above steps to reset the SA password on all servers in the cluster.
//Jorge
07-12-2007 08:22 AM
thanks very much for this.
regards
dave white
