Password Protection for Cisco IP Phones
Hi Folks,
I have a number of cisco IP phones 7941, 9971 etc that I like to password protect to avoid  unauthorised persons calling out on the phones. I have tried using the common phone profile under Device settings on CUCM 7.1.2 to no avail.
FAC has been sabotaged and found useless since FAC codes assigned could be used on another phones in the same Partition.
Please any solution is appreciated.
Also, is there a way I can use ACL on CUCM to avoid calls dialling after work hour except a specific password is supplied after a prompt on each phone.
Thanks in anticipation.
Hi Caleb.
You could use Extension Mobility feature or third party app.
Here is a useful post
https://supportforums.cisco.com/message/3338664#3338664
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo,
Please are there free 3rd party apps, please name nice ones.
Also, can you guide me on how to use extension mobility to get this done.
VIP Purple
Hi Caleb,
you can use  Andtek.
http://www.andtek.in/communications-products-lockout.html
regds,
aman
Hi Caleb.
My buddy Aman, has been faster  (+5)
With Extension Mobility user can migrate his extensions and phone features to another phone just logging into the phone.
When logged out, the Phone could have an extension able to call internal DN only.
You can refer to the following doc to have an idea on how to configure this service.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsgd-712-cm/fsem.html
Carlo
You can also involve TOD on this if you need this based on time.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Please, I need the TOD, can I have a guide to configuring it?
Thanks!
Re: Password Protection for Cisco IP Phones
Hi Caleb.
Here you have a doc
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/accm-861-cm/a03tod.html
Carlo
265
