Password Recovery on Unity Express CLI
I can access Unity Express on the GUI, but I am unable to log into a CLI session on the service-module - GUI administrator login does not work.
How can I recover the CLI username/password?
1 ACCEPTED SOLUTION
Re: Password Recovery on Unity Express CLI
Are you running AAA on the router? Can you create a local user on the router and try to login with this username/password?
Brandon
Are you being asked for a username/password after "service-module service-enging 0/0 session"? If so, check the line for the CUE module. In your router config, along with "line vty 0 4", etc you will have something similar to "line 194". Is this line set to require a login? If so, remove the login command.
Hope this helps.
Brandon
No login command, I'm afraid. Here's my line config:
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
transport input ssh
line vty 5 100
access-class 23 in
transport input ssh
Stu
Are you trying to get to the CUE module CLI from the router? Are you being prompted for username/password after "service-module service-enging 0/0 session"? Is it prompting for username/password or just password?
Brandon
Yes I am, and I'm being prompted for both the username and the password.
Brandon
Perfect! Thanks...
I'm facing similar issue,
I'm facing similar issue, however its Prompting just the Password.
Any help is highly appreciated.
Did you check your line
Did you check your line configuration? For example:
line 194
login
transport preferred nonetransport input all
Do you see the "login" command as above? If so, remove this command using "no login"
Brandon
2366
