Community Member
PATCHES FOR CCM 4.2
can someone suggest me what all patches are required for ccm 4.2(1).
thx for ur help.
VIP Purple
Re: PATCHES FOR CCM 4.2
You can find patches/updates for CCM 4.2 here:
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-42
See the following link for a list of recommended and supported updates for the OS, SQL, etc.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm
Hope this helps. If so, please rate the post.
Brandon
Community Member
thxx buffin,
i have ccm4.2 freshly installed and i was not able to get phones up .7970 is showing "ctl update failed" though its showing ip address and rest of setting .
the 7912 phones are not coming up they are getting all configuration but struck and keep on showing "configuring ip" i dont know where i am wrong as the ip communicator is working fine.need help on this.
so i thought of patching it.
thxx again for your help.
sandeep
114
