Pause between inter digit
Dear All,
Possible to do a "pause" between inter digit in a route pattern.  we are exploring telco service to save phone cost.  The provider require a "pause" on route pattern.  I am using CCM 4.3.
Is CCM 4.3 having this feature?
Lum
1 ACCEPTED SOLUTION
No, you cannot in CUCM.
If you have H323 GWs you could explore using the , there in the DPs for the timeout.
If you use MGCP, there's just no way to do it other than have your users do that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
VIP Super Bronze
Can you please clarify what you mean by a pause on route pattern? What are you trying to achieve
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Aokanlawon,
We are subscribe the save cost service, every PSTN call require dial 1800871111 continue destination number.  The provider require us to configure the route pattern 1800871111 pause 1 to 2 second then continue destination number.
Lum
Re: Pause between inter digit
Lum,
If you meant " Pause in speed dials ", then CUCM 9.0 has this new feature, before that ( in earlier versions ) pause in dialing was not allowed. Please refer http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_0_1/delta/CUCM_BK_N38FD301_00_new-and-changed-information_chapter_01.html#CUCM_RF_P88E2D85_00
GP.
Pls rate helpful posts by clicking on stars below the post !!
Hi Gajanan Pande,
Not in speed dial.  we want to do it at pre-fix at called party in route pattern.
Lum
java
java
Hi Java,
What you mean "other than have your users do that"?  Do you mean phone user can do the "pause"?
um
863
