PAWS-M upgrade to PCD.
Evgeniy.Suvorov
Hi all. I have PAWS-M installed. Is it possible to upgrade PAWS-M to PCD or not ?
Jaime Valencia
PAWS-M is an interface on CUCM, PCD is an application that uses PAWS-M, not sure what you're asking here.
Id suggest yo to read the PCD documentation.
java
if this helps, please rate
Hi Jaime.
I think that you are wrong. PAWS-M is stand alone application that was introduced in CUCM 9.
Also there is the documentations for it
In CUCM 10.5 introdice PCD, but there isn't any informatin about how to upgrade PAWS-M to PCD.
Interesting, I only knew of the API in the UC apps, however, PCD does not upgrade from anything else, you need to fresh install PCD the first time, and then upgrade with the PCD upgrade files. FYI, PCD was actually introduced in 10.0
java
