09-01-2017 09:07 AM - edited 03-17-2019 11:06 AM
Does anyone have any knowledge/experience of getting a Paxton Net2 door entry device registered to a CME as a third-party endpoint? We have a voice register pool device configured with a username and password, and this works becuase a SIP softphone (like X-Lite) can register & place calls using these details. The Paxton Net2 however will not register. Thanks.
09-04-2017 07:18 PM
can you add the debug ccsip message to the post.
please rate if helpful
10-17-2017 02:53 AM
10-17-2017 03:19 AM - edited 10-17-2017 03:22 AM
05-18-2018 08:48 AM
Did you ever manage to get the Net 2 Door entry working with CME?
I have a customer who has purchased a door entry and wants to integrate with CUCM.
If you get it registered as a SIP client can you then configure a speed dial or number that is dialled when the buzzer is pressed?
Oli
05-18-2018 08:51 AM
I'm afraid not Oli, although the Net2 implementer in my case had checked CUCM compatibility rather than CME, so I got the impression info on configuring these for CUCM was much more readily available.
Dan
05-18-2018 08:54 AM
05-18-2018 09:23 AM
05-18-2018 09:30 AM
Agreed. But we had a third-party SIP endpoint configured in CME, and X-Lite was able to register to the CME and place calls without any issue. Provided details to Net2 implementer and they were unable to get the device to register. CME was returning a '401 Unauthorized' to the device but Net2 engineer insisted the provided credentials were being used.
05-18-2018 09:36 AM
05-18-2018 08:10 PM
Oliver, 2N helios integrates quite nicely with cucm. and yes is essentially a 3rd party SIP device from a cucm point of view. its button(s) are essentially speed dials. and it can be used to open a gate using DTMF.
