pb backup on ccx
I have a problem with backup the cisco unified contact center express 7.0(1)SR05_Build504
I have the following error :
Java Plug-in 1.6.0_12
Using JRE version 1.6.0_12 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Administrator
load: class com.cisco.archive.impl.applet.ArchiveApplet.class not found.
java.lang.ClassNotFoundException: com.cisco.archive.impl.applet.ArchiveApplet.class
    at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
    at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
    at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Unknown proxy type : HTTP
    at java.net.SocksSocketImpl.connect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at sun.net.NetworkClient.doConnect(Unknown Source)
    at sun.net.www.http.HttpClient.openServer(Unknown Source)
    at sun.net.www.http.HttpClient.<init>(Unknown Source)
    at sun.net.www.http.HttpClient.New(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
    at java.net.HttpURLConnection.getResponseCode(Unknown Source)
    at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
    at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
    at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    ... 7 more
Exception: java.lang.ClassNotFoundException: com.cisco.archive.impl.applet.ArchiveApplet.class
Have you got an idea ?
Best regards,
Guillaume
Everyone's tags (2)
1 REPLY
pb backup on ccx
Noone ?
187
