PBX Caller-ID issues
I have a T1-PRI tie line between the PBX(Avaya G3) and my Call Manager 5.1 w/2811 voice gateway. The issue is getting the caller-id to work on calls coming from the Avaya. The company that handles the Avaya says they are sending the Caller-Id but all I get is the extension the user is calling from. Running a debug here it the output I get.
*Jun 15 14:24:17.765: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0xE395
*Jun 15 14:24:17.789: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x6395
*Jun 15 14:24:20.917: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x642C
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98386
Exclusive, Channel 6
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0xA1, '8353'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '8460'
Plan:ISDN, Type:Unknown
Locking Shift to Codeset 6
Codeset 6 IE 0x55 i = 0x010002050500, '85', 0x00000310, 'H', 0xA600000200000000000000000000000000
Codeset 6 IE 0x55 i = 0x0A0202050500, '85', 0x00000310, 'H', 0xA600000F00, 'Server Room Dow'
*Jun 15 14:24:20.933: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xE42C
*Jun 15 14:24:20.933: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xE42C
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Jun 15 14:24:23.597: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x642C
Cause i = 0x8190 - Normal call clearing
*Jun 15 14:24:23.609: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8 callref = 0xE42C
*Jun 15 14:24:23.641: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x642C
If any one has any ideas they would be helpful.
Gold
Re: PBX Caller-ID issues
I believe this is the issue with the Codeset being used to send Caller ID. Can you try to have them send it using Codeset 0. CallManager does not support Codeset 6.
I believe to for the display name to work on Avaya the following will have to be done. Go to the trunk-group configuration and change the parameter "Codeset to send display" from 6 to 0.
Hope this works.
I have a similar problem with Avaya /Cisco call. Did the change of "codeset to Send Display: 0" resolved the problem?.
Did you have to change other parameters in the Avaya o in CISCO gateway?
Thanks in advance
Are you using QSIG/MGCP/T1 ? I have several customers working in this format. Without QSIG you won't get supplementary features like Calling Party Name. There is a PBX integration guide;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/410364av.pdf
I am using QSIG/EI/H.323 with a 2851 gateway (version 12,3(14T6) and a call manager express 3.2 in a router 3745. Calls from Cisco to Avaya are o.k but calls from Avaya to Cisco can't see caller name.
Next debug isdn q931
*Oct 20 10:44:49: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref = 0x1B85
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Channel ID i = 0xA18386
Preferred, Channel 6
Facility i = 0x9FAA068001008201008B0100A1100202967306072B0C0287780104040100
Facility i = 0x9FAA068001008201008B0100A11802029674020100800F4962617272612C2047696C62657274
Calling Party Number i = 0xA1, '7022'
Called Party Number i = 0xA1, '7266'
*Oct 20 10:44:49: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x9B85
*Oct 20 10:44:50: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x9B85
*Oct 20 10:44:55: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x9B85
*Oct 20 10:44:55: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x1B85
*Oct 20 10:45:05: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x9B85
Cause i = 0x8090 - Normal call clearing
*Oct 20 10:45:05: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x1B85
*Oct 20 10:45:05: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9B85
Carlos
Hi Carlos,
You may want to try this command:
Serial0/0:23
isdn supp-service name calling
You need QSIG setup on your PBX trunk between your callmanager.
You should use the MGCP between Callmanager5.1 and W/2811. Because H.323 can't deliver the call-id/calling name. Also QSIG should be configured between the 2811 and AVAYA PBX on the T1-PRI line.
Last week I encounted the same issue as yours. But my PBX is SIEMENS, and i resolved it using the MGCP/QSIG.
737
