PBX to Gateway Integration - Caller ID
If we a PRI from telco that connects into a cisco gateway, then also attached to the cisco gateway we connect to a legacy PBX (via bak to back PRI connection but no Qsig) will the caller ID (number and/or name) be able to be extended to the PBX? We're also connnecting to a CME via this gateway but want to ensure that caller ID can get to PBX.
thanks in advance
Anonymous
N/A
Re: PBX to Gateway Integration - Caller ID
The Cisco Unity IP Media Gateway products are integration devices designed to offer a connection between Cisco Unity or Cisco Unity Connection servers and your existing traditional private branch exchange (PBX) so caller ID can be extended to the PBX.
does PIMG limited for some countries , can i use it here in Egypt ??
144
