PBX to PBX using 1721
Is it possible to connect two PBXs together with 1721?
The diagram is attached herewith...
Please help
1 ACCEPTED SOLUTION
Re: PBX to PBX using 1721
No. You can't do it.
hth,
nick
This is a voice capable router, so you should be able to. Doing hairpin analog calls should be something very manageable.
Hi Eldho,
Apologies. The data sheet I was looking at grouped the 1721 with the 1751-V. It didn't sound right, but I wasn't going to argue with a data sheet.
So the correct answer is no - you would need a 1751-V minimum to connect two PBXs together.
hth,
nick
I guess the two PBX are at different sites. If so, then you shoud be able to integrate them using two VG or two Voice capable router with analog or digital trunks.
That i know....But the question is it to possible with 1721 router???
hth,
nick
138
