PCM Capture Extraction Tool
Muhammad Nawaz
How can i get   PCM Capture Extraction Tool to create audio file?
Jaime Valencia
Unfortunately that's a Cisco Internal Tool
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
      Thanks for quick response.Cisco should provide such tool to Cisco partner. that will be help to fix issues on right time. otherwise  back and fourth communication required between Cisco and Partners to fix the issue.
Nawaz
