05-13-2010 03:32 AM - edited 03-15-2019 10:44 PM
How can i get PCM Capture Extraction Tool to create audio file?
Solved! Go to Solution.
05-13-2010 06:44 AM
Unfortunately that's a Cisco Internal Tool
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-13-2010 06:44 AM
java
05-13-2010 07:11 AM
Thanks for quick response.Cisco should provide such tool to Cisco partner. that will be help to fix issues on right time. otherwise back and fourth communication required between Cisco and Partners to fix the issue.
Nawaz
