Community Member
Permanent tone on vg224 when analog phone goes offhook
i have here a strange behavior on a cisco vg224.
On all sccp ports, when you go offhook, you here a permanent tone, instead of the dial tone.
Devices are registered to the callmanager and can do a phonecall.
show version:
Cisco IOS Software, vg224 Software (vg224-I6K9S-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
System image file is "slot0:vg224-i6k9s-mz.151-3.T4.bin"
config:
voice-port 2/4
no supervisory disconnect lcfo
no battery-reversal
no echo-cancel enable
no vad
playout-delay fax 40
no comfort-noise
cptone DE
timeouts ringing infinity
bearer-cap 3100Hz
caller-id enable
dial-peer voice 204 pots
no tone dialtone remote-onhook
tone busytone remote-onhook
service stcapp
port 2/4
I tried it with and without this commands. I tried the solution from this cisco document; but it did not fix it:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805552e9.shtml
voice-port 2/4
no battery-reversal
Everyone's tags (2)
Michael,
Dialtone is managed by the network locale on the cucm page for that analog sccp endpoint..
Or you can directly change it (cptone) under voice-port like this..
voice-port 2/4
cptone ca   >>> ca is for canada..
please try this change and let me know the result.
Piyush
Community Member
Re: Permanent tone on vg224 when analog phone goes offhook
i went throug some Cisco TAC Cases and the answer is, it is a bug and only workarounds are available till now:
Workaround for wrong dialtone (priviliged commands)
test voice tone DE dialtone 1 425 0 -200 -200 -240 0 0 0 200 300 200 300 200 800 0 0
test voice tone DE 2nd_dialtone 1 425 0 -200 -200 -240 0 0 0 200 300 200 300 200 800 0 0
Script for activating the priviliged commands after reboot:
event manager applet dialtone
event syslog pattern "%SYS-5-RESTART"
action 1.0 syslog msg "custom dailtone"
action 2.0 cli command "enable"
action 3.0 cli command "test voice tone DE dialtone 1 425 0 -200 -200 -240 0 0 0 200 300 200 300 200 800 0 0"
action 4.0 cli command "test voice tone DE 2nd_dialtone 1 425 0 -200 -200 -240 0 0 0 200 300 200 300 200 800 0 0"
action 5.0 syslog msg "Custom dialtone for DE configured"
The command to check the corresponding frequencies is:
test voice tone DE show
If you have issues with fax machines, this second workaround can help:
conf t
voice-port 2/xx
no cptone DE
478
