Persistent Ephone MAC
Is there a way to manually clear the ephone MAC address from a ephone tag entry without rebooting?
That failing, is there a timeout value to remove a clear ephone MAC address or does the ephone MAC stay in a unregistered state in the database until a reboot occurs?
1 REPLY
Hall of Fame Super Gold
Re: Persistent Ephone MAC
The mac must time-outfirst and it takes like 10 min. After that you will be able to assign a different mac.
184
