Community Member
Personal Adress Book Entry Names on Phone Display
Is it possible to display the name of a caller which is stored in the PAB on the phone display? We can see only the caller-id of the incoming call, not the stored name in the PAB entry.
Marcus
1 ACCEPTED SOLUTION
Re: Personal Adress Book Entry Names on Phone Display
sorry, CUCM does not have that capability
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
158
