Personal directory calls only 5 digits
I have a problem with the personal directory with the callmanager 8.6, when a user configures his personal directory with external numbers and he place a call from his personal directory, only 5 digits are formed, I did search for a parameter that can be involved but could not find one.
Someone who has some suggestions ?
Peter
Are you matching something that's translating that number?? called party transformations?? TPs??? RPs? RL??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I did check for matches but no match, I should have it also when I place a call
Re: Personal directory calls only 5 digits
Any news about this?
I have the same problem with 8.6.2.20000-2. The difference is that it only sends 3 digits.
I have checked everywhere I can remember but no luck.
Phone models 69xx.
Best regards
315
