Community Member
personalised ring tone for different users
Hi.
Is is possible to configure seperate ring tone for each user based on the caller number or caller name in cisco ip phone 7906G. please guide me how to proceed with the same if it is possible.
thanks and regards
Rajesh
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: personalised ring tone for different users
Sorry, that it is not possible.
Community Member
Hi All,
Will above feature support for any model of IP Phone? Can any one provide a dcoument for refernce if not possible
Asif
This is not available in any phone model and also not available in CUCM/CME.
There is no document that says you cannot do this, we document what's supported, and there is no document that covers that feature.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
173
