PGW 2200 9.7(3) + AS5400XM problem
Hi to everybody.
i have Cisco PGW2200 9.7(3) with latest patches installed (system and protocol). When i'm trying to make the PGW active, my gateways starting to constantly reload with following text: (see attachment - cons_output.txt)
IOS version on all Cisco 5400XM is - c5400-is-mz.124-11.XW2.bin
Does anybody know about problems between PGW 9.7(3) and IOS 12.4(11)XW2?
Should i upgrade my 5400 IOS? But what version of IOS i need to upgrade to?
Silver
Re: PGW 2200 9.7(3) + AS5400XM problem
Try to disable CDP by entering the no cdp run global configuration command. Also check for a Layer 2 problem.
Thank you for the reply, but why do you think it is CDP problem?
With PGW 9.5(2) everything works just fine.
I've opened a case on Cisco TAC about this problem. Now waiting for the reply.
130
