Community Member
Philips Sopho PRI + CCME4.1
I want to integrate a PBX Philips Sopho with a Cisco CME setup using an E1 (QSIG) connection to the PBX.
I'm getting this error from debug:
Jul 5 09:08:50.808: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5F00
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA3
Preferred, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '2456'
Plan:ISDN, Type:Unknown
Jul 5 09:08:50.808: ISDN Se0/0/0:15 Q931d: L3IF_rx_L2_pak: received data
Jul 5 09:08:50.808: 08025F000504039090A31801A31E0281
Jul 5 09:08:50.808: 836C06018032343536
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x020A, event 0x0005, call id 0x int id 0x0
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x5 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0x0000 old UNKNOWN_STATE, new NULL_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x0 cr 0xDF00 state 0 event 0x5 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 SETUP:U0_Setup(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0x0000 old NULL_STATE, new UNKNOWN_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x0400, event 0x0087, call id 0x int id 0x2F
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x87 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x2F cr 0xDF00 state 0 event 0x87 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 CC_BROADCAST_RESP:U0_BroadcastResp(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0xDF00 old NULL_STATE, new CALL_PRESENT
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: source 0x0400, event 0x0082, call id 0x int id 0x2F
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: event 0x82 cr_len 2 cr 57088
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_Go: call_id 0x2F cr 0xDF00 state 6 event 0x82 ces 1
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_ProcessEvent: callref = 0xDF00 CC_SETUP_REJ_REQ:U6_SetupRejReq(nlcb)
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_TxSarMsg: InfoLen = 10 octets
Jul 5 09:08:50.812: 0802DF005A080380E418
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: srl_send_l3_pak:
source_id = Q.931 0x0300, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
priv_len = 4 int_id = 0x47C1C7C4 datasize = 26
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: data =
Jul 5 09:08:50.812: 47C1C7C4000003000240040000010806
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931d: L3_state_change: callref 0xDF00 old CALL_PRESENT, new NULL_STATE
Jul 5 09:08:50.812: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xDF00
Cause i = 0x80E418 - Invalid information element contents
Any ideas?
Cheers,
Hefin
Hall of Fame Super Gold
Re: Philips Sopho PRI + CCME4.1
Which IOS are you using ? Config ?
The thing is that called number is missing in setup, what number where you calling ?
Community Member
IOS versino 12.4(11)XJ3, with CUME 4.1
I'm calling from an exchnge number 2456, to 1000 which has been assigned to the CCME. As you said, there isn't a 'Called Party Number' there.
Ok, can you trying configuring:
voice service voip
qsig decode
and take another 931 trace.
Something a bit strange is that you have the router in user-side, not network. To what the PBX was connected before, if anything? Do you have access to the PBX configuration ?
Community Member
I'll try an get the configuration changed over so that the router is the master, and the PBX as the slave.
Let you know how we get along
Cheers,
Hefin
Ok, but from the config you sent, it appears this is already the case.
Community Member
Ok, re-configured the isdn switch-type to be primary-net5 and everything now works.
Anybody know if there are any issues with runing a CCME system with a net5 connection?
There are no issues, net5 is the most used switchtype worldwide.
Please remember to rate useful posts using the scrollbox below!
947
