Community Member
Phine load not coming down to phones.
I am trying to install the newest firmware (P00308000800) to my 7940, under the default devices it says that it is there, I reboot my phone and the old firmware is still registering on the device.
Any thoughts?
-J
1 ACCEPTED SOLUTION
Re: Phine load not coming down to phones.
enter the new firmware version on the device config page, update, reset the phone
java
if this helps, please rate
www.cisco.com/go/pdi
java
Community Member
Ensure that all the files for the firmware are included in the tftp statement. e.g.
tftp-server flash:/C7940-60/P00308000500.loads alias P00308000500.loads
tftp-server flash:/C7940-60/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/C7940-60/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/C7940-60/P00308000500.bin alias P00308000500.bin
Note the alias statement is only required if the files are located in a directory other than the root directory.
Then update Telephone-service configuration includes the updated load statement and remember to create the config files.
E.g.
telephony-service
load 7960-7940 P00308000500
create cnf-files
HTH,
Cheers,
166
