Community Member
Phone 6901 show red color only?
Dear all,
Do you know how to troubleshooting on phone 6901 show only red color ? when i plug cable to telephone it show the light only red color.
please advice.
Best Regards,
rechard.
Rechard, Are you talking
Rechard,
Are you talking about the Handset light strip ?
How many phones are behaving this way ?
Gagarin
Regards, Gagarin Please rate all helpful posts.
Community Member
Dear Gagarin, Please see in
Dear Gagarin,
Please see in the attach file.
Please help to advice !
Best Regards,
Rechard
Hi Rechard, If the phone is
Hi Rechard,
If the phone is unresponsive and if it is stuck in this stage it is more likely a hardware issue.
Gagarin
Community Member
Dear Gagarin, you mean that
Dear Gagarin,
you mean that hardware problem right ? cannot fix?
Currently i have only one issue .
Please advice.
Best Regards,
rechard.
Hi Rechard,If its just one
Hi Rechard,
If its just one phone, then the symptoms does looks like a hardware issue.
Gagarin
Community Member
Dear Regards, Do we have
Dear Regards,
Do we have guide line to check the error ? how to troubleshooting on this?
Best Regards,
Rechard
Bronze
Have you tried to do the
Community Member
Dear Matty, i tried but it
Dear Matty,
i tried but it show only red color cannot do anything.
Does it problem with IOS?
how can i upload new IOS in to this phone?
Best Regards,
Rechard
Bronze
I guess the phone has worked
I guess the phone has worked at some point?
I don't think a new phone firmware would help.
Maybe get a network sniff on the port it is connect to and see what it is doing?
What platform are you using? CME? CUCM?
Matty
102
