You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Phone 7910 can´t make calls on CUCM 8.5
We are doing an upgrade of CUCM from 4.1 to 8.5 and the problem is that the phones 7910 G+SW are registered correctly to CUCM 8.5, can receive calls normally but can´t make calls.
The simptoms when we try to make a call are the follow:
- The phone have no dial tone.
- can´t press no digit.
- after 4 seconds the congestion tone is hear in the phone.
Actions already taken:
-We check 4 phones 7910. All have the same symptom.
-The firmware version P00405000700.sbn (signed) recommended by Cisco is installed by default in CUCM 8.5.
-Create new profiles for phones 7910. The result is the same.
Other tests:
-Web dialer works properly.
-Speed dialer works ok.
  • IP Telephony
301
