Phone 8961 doesn't boot
i have a 8961 phone which doesn't start.
Only the upper both buttons are orange, screen is black, and the "navigation" kay is blinking some times.
I've tried the pressing # while "startup" and then 123456789*0# procedure but it doesn't work.
Does anyone knows how to reactivate the device?
Thanks a lot.
regards
Thorsten Könsgen
  • IP Telephony
Everyone's tags (1)
Bronze
Hello ThorstenHave you
Hello Thorsten
Have you checked if the Phone receives enough power?
If possible try to boot the phone with a external power supply.
Best Regards
slashdots
Hello slashdots, thank you
Hello slashdots,
thank you for your reply.
The phone is connected to an external power supply. I've tried different power supplies (PWR-C-4).
So this does not to be the problem :-(
best regards
Thorsten
Same problem occured today.
Same problem occured today. Powered over Ethernet. Spooky coincidence !
