Community Member
Phone button template on CUCM 7.x
I have created a new template and it is not showing up in the drop down when building a new device?
Hall of Fame Super Silver
Re: Phone button template on CUCM 7.x
is it for the correct device type?
Community Member
Yes it is the same device type. It will show up in find and list phone button templates but when I go to build a new phone or change the phone button template it does not show up in the drop down list.
how is your database replication looking?
Hall of Fame Super Red
Hi Kevin,
Can you please tell us the phone model you are trying to add a template for
and the exact CUCM version you are running??
Cheers!
Rob
309
