phone call duration timer on display
Hi All, Is there a way to remove the call duration timer on phone display or add another line to the calling number information? If we get a call in with a particular long number i.e. international then the last few numbers are hidden by the duration timer.
1 ACCEPTED SOLUTION
Re: phone call duration timer on display
sorry, no way to take it out from the phone
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
124
