Phone Change Logs
I am trying to find the logs that show when a 7960 phone was added or modified in CCM4.1(2). Does anyone know where this log file might be located? Thanks in advance.
1 REPLY
Green
Re: Phone Change Logs
If you are using MLA you can find them under Program Files|Cisco|Trace|MLA
Otherwise I only would check IIS logs.
Or start thinking in CUOM or other Cisco Management Tool for Access.
99
