11-15-2013 08:27 AM - edited 03-16-2019 08:26 PM
Will the background images done through Phone Designer stay on the phone if the CUCM is upgraded? I remember reading somewhere that the images are part of the phone, so I would assume it would stay, but I'm looking for verification.
Solved! Go to Solution.
11-15-2013 10:43 AM
No, they will stay there until you do a factory reset or change the image.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-15-2013 09:16 AM
Yes, once the image is loaded onto the phone it's not different if you had done it manually on the phone from the List.xml.
java
11-15-2013 10:41 AM
Thanks for the quick response, but perhaps Im not asking the right question. If the phone is currently using CUCM6, and , the CUCM is upgraded to v9, will the phone lose its background?
11-15-2013 10:43 AM
java
