Phone directory integration
Does anyone know if there is a way to integrate phone directories from two independant CM clusters so that the other site can see it?
CM 4.1.3sr6
1 REPLY
Re: Phone directory integration
that would require you to write down your own directory script or to modify the one that's provided to accomplish that
other option would be to use AD and have them both look at the same user search base, meaning integrate both to the same AD
java
if this helps, please rate
java
www.cisco.com/go/pdi
99
