Phone Feature Question
I have a customer that wants a feature that i dont think CUCM can do but I wanted to run it by everyone for suggestion. The users wants the receptionist to be able to page him across the speaker phone if he is already on a call. Any help would be great...Thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
it works as whisper, meaning the intended intercom recipient will hear this second call stream, while the existing caller on the phone will not, which sounds like what you want.
Chris
Paging is not a feature of CUCM at this time, you can look at 3rd party, i.e. Singlewire Informacast, and others.  Also, if this is just one to one paging relationship you may want to look at Intercom feature, which is available on CUCM.
HTH,
Chris
I am not sure if this is one to one but if it is if that users was on the phone would it put his call on hold while the intercom was active or could he still be talking to the client while the receptionist talks across the speaker?
Chris
Awesome,  that is exactly what I think the user wants. Thank You
203
