Phone Firmware upgrade process
Community,
I have a installation of Call Manager Express running version 4.x.  I am trying to upgrade to Call Manager Express 8.1
However, the phones will not upgrade when connected to the new CME running version 8.1
I suspect there is a version sequence upgrade process to follow, which is difficult to figure out.
Has anyone done this or have information on how to do it?
Thanks.
Everyone's tags (2)
What FW do they have and which one are you trying to push??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi, these are the firmware loads as defined on the CME routers:
Call Manager Express 4.1(0) loads
telephony-service
fxo hook-flash
load 7910 P00405000700
load 7960-7940 P0030702T023
load ATA ATA030100SCCP040211A
load 7920 cmterm_7920.4.0-02-00
load 7961 SCCP41.8-0-4SR2S.loads
load 7971 SCCP70.8-0-4SR2S.loads
load 7970 SCCP70.8-0-4SR2S.loads
Call Manager Express 8.1  loads
load 7960-7940 P00308010200
load 7961 SCCP41.8-5-4S
load 7970 SCCP70.8-5-4S
load 7971 SCCP70.8-5-4S
load ata ATA030203SCCP051201A
Have any directions, suggestions to get them to upgrade?
Thanks.
Review this:
Cisco Unified IP Phone Release Notes for Firmware  Release 8.5(3) (SCCP and SIP)
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from  firmware release versions earlier than 8.3(3) to version 8.5(3) or  greater, you must first upgrade your firmware to version 8.5(2). Once  you have upgraded to version 8.5(2), you can upgrade your IP Phone to  version 8.5(3) or later.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html
Review the related documentation for the other phone models to confirm they're not affected by something similar.
java
java
531
