Phone / Gateway Setup - Remote Location
We have an office in an extremely remote location that connects to the Internet using a Satelittle connection. The average response time from this office to our core office is approx 800-1200ms on average.
Currently, we have an 1811 in place, which has a voice and data vlan. The voice vlan has a vpn tunnel setup directly to our core, where the phones register with call manager. There are no phone lines / voice gateway at the remote office.
This is not the ideal setup as we have serious voice quality issues, etc. Just wanted to start a discussion on some options for the ideal setup at this location (SIP TRUNK, VOCIE GATEWAY, CM EXPRESS, other?)
Look forward to hearing some ideas / opinions.
Green
You are away outside the limits for VOIP
Minimize delay between Cisco UCM and remote locations to reduce voice cutthrough
delays (also known as clipping ).
The ITU-T G.114 recommendation specifies a 150 ms maximum one way.
I can see how you can make this sound good at 800-1200 msecs
Looks like you would need to use CME at the remote site as a stanalone and use the PSTN to call outside
Alex
Regards, Alex. Please rate useful posts.
Super Bronze
I'd agree - you can use CME for the remote site, thereby keeping the SCCP traffic local.
For calls to HQ etc you can route via the PSTN, or set up a SIP trunk abck to the CUCM and try your luck. I've seen SIP trunks work acceptably with <2 sec call setup time on WANs running 600-700ms latency one way. Once calls were running there weren't any major issues though I expected to get problems due to the delay (i.e. people talking over each other etc).
H.323 by comparison would take around 7-8 seconds on the same WAN. SCCP is pretty chatty so I would expect significant delays in most things - getting dial tone, dialling numbers, etc...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
212
