02-13-2012 06:19 PM - edited 03-16-2019 09:34 AM
I am getting a strange issue whereby even after I hang up the phone after 5-6 rings where the other party is not picking up the phone.
The phone still rings. Its only when I off hook the phone and on hook the phone again, the call ends.
On the LCD display, I still see that the phone is calling the other party despite already ending the call.
This happens on and off.
How do I troubleshoot this issue ?
02-13-2012 07:04 PM
What is the phone model, What is the CUCM version.
What is RTT between Phone and CUCM. Also it is happening to other phones also.
Ronak Patel
02-13-2012 07:12 PM
phone model is 7945G, CUCM is version 8.5.1.
RTT from phone to CUCM is 0.5ms.
so far only one user have reported this issue.
it happens during IDD calls.
02-13-2012 09:26 PM
I think this might be problem with the hardware. You may raise TAC case and see if RMA can be raised.
Ronak patel
02-13-2012 09:38 PM
you might also want to check the CPU speed of call manager at the time of issue..is it too high or not??
02-13-2012 09:41 PM
Certainly not an hardware issue. How do you connect to PSTN? If ISDN, can you take "debug isdn q931" with "term mon" on the gateway, for a troubled call.
