Community Member
Phone icon w/ x symbol
On my 7915 expansion module one of my speed dials icons is displaying a phone icon w/ an x symbol on top of the phone.
Anyone have any quick ideas? Tried power cycling the end users phone but the status symbol stays the same and the light is red.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Ryan,
I believe that would mean the monitored phone is
currently in DND (Do Not Disturb) state
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hi Ryan,
Cheers!
Rob
- The Band
Community Member
Re: Phone icon w/ x symbol
I thought I had checked that! I will have to double check and report back. This could just be an oops on my part.
Thanks for the response --- will update when I know.
Community Member
Well, Rob, you saved the day. Not sure how I missed this one! Thank again!
Hi Ryan,
You are most welcome my friend!
Glad to be of some small help here
Cheers!
Rob
- The Band
142
