Community Member
Phone in Fallback mode... Available line 0 ???
I have an issue with the SRST on a remote site. We had a network failure, and here is the "show ephone registered" during Fallback mode:
ephone-5[4] Mac:0024.142D.46DD TCP socket:[2] activeLine:0 REGISTERED in SCCP ver 15/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.247.230.66 51293 7941  keepalive 5 max_line 2 available_line 2
button 1: dn 2  number 5124  CM Fallback CH1   IDLE
Preferred Codec: g711ulaw
ephone-6[5] Mac:0021.A085.5373 TCP socket:[8] activeLine:0 REGISTERED in SCCP ver 15/9
IP:10.247.230.65 51777 7961  keepalive 25 max_line 1 available_line 0
As you can see, ephone 5 and 6 are "registered", but ephone 6 has the field "available_line" set to "0".
On the phone, we can see "SRST Fallback Mode Operating" but no line on the phone.
The Network config on the phone shows "Secondary Callmanager: Active"
It's very strange why no line comes up on this specific phone
I already upgrade the IOS on the 2800, it's not better.
Anyone help ?
Thx
Fabian
Re: Phone in Fallback mode... Available line 0 ???
It's pretty hard to say something without the config info.
Check/increase "max-dn"?
Community Member
Don't think it's related to this field since I have only 7 ephone and 9 dn on this site...
But here is the "sh call-manager-fallback":
LuxOffice#sh call-manager-fallback
CONFIG (Version=7.0(1))
Version 7.0(1)
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip source-address 10.247.230.126 port 2000
max-ephones 30
max-dn 30
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
huntstop
no huntstop channel
huntstop channel 0
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
Limit number of DNs per phone:
  12SP: 56
  7902: 56
  7905: 56
  7906: 56
  7910: 56
  7911: 56
  7912: 56
  7920: 56
  7921: 56
  7925: 56
  7931: 56
  7935: 56
  7936: 56
  7937: 56
  7940: 56
  7941: 56
  7941GE: 56
  7942: 56
  7945: 56
  7960: 56
  7961: 56
  7961GE: 56
  7962: 56
  7965: 56
  7970: 56
  7971: 56
  7975: 56
  7985: 56
  anl: 56
  ata: 56
  bri: 56
  CIPC: 56
  vgc-phone: 56
Log (table parameters):
     max-size: 150
     retain-timer: 15
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Community Member
I got a similar problem:
CUCM 9.1.1a
Cisco 2821 running c2800nm-ipvoice-mz.151-4.M6.bin
SCCP IP Phones 7941 & 7942
My IP phones are registering on VGW, but don't have a line. I tried many loads for the IP Phones (8.5.4 till 9.3.1) and other IOS 12.4.24T on VGW, but still no phones registering with a DN.
Have you found a solution?
Greets,
David
Community Member
Hi David,       I got the
Hi David,
       I got the same issue with you. I wonder if you have resolved it ? how to do it ?
      Thanks in advance!
Community Member
Hi Tom,If you set an old load
Hi Tom,
If you set an old load, then the phones will have the DN. But the old load will not work with +E.164 numbers, so this was not a solution for me. And Cisco doesn't do any development anymore on those old phones, so SRST is not working as it should...
Greets,
David
2805
