Phone keys not triggering any action when prompted by any external IVR
Hi everyone,
Please I have a Voip network that has a CME Router 2921. Calling out and receiving through the PSTN works fine but I notice that whenever any of the phone calls an outside number that is using IVR (eg calling help lines that has auto-attendant saying press 1 for xxx, press 2 for yyy, and so on) and being prompted to press different keys for various options. Non of the keys would give any response. These non-response is the same for any IVR enabled public number that I call from the phones in the network. When I use my GSM phone to call such numbers my call was directed appropriately after pressing the keys as prompted by the voice prompt. Is there any special configuration that has to be done on CME to allow this to work?
Here is an excerpt of the CME router config
hostname CME
boot-start-marker
boot-end-marker
card type e1 0 0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h225-notify cid-update
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.19.0.2 port 5060
max-dn 4
max-pool 2
load 9971 sip9971.9-1-1SR1.loads
load 9951 sip9951.9-1-1SR1.loads
authenticate register
authenticate realm all
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0008765166362568
ntp-server 64.209.210.20 mode directedbroadcast
voice register dn  1
number 3814
name User1
label User1
voice register dn  2
number 3850
name User2
label User2
voice register pool  1
id mac D911.BDF1.6430
type 9951
number 1 dn 1
cor incoming loc-mob default
dtmf-relay sip-notify
username cisco password cisco
codec g711ulaw
no vad
voice register pool  2
id mac A321.30BB.4E7D
type 9971
number 1 dn 2
cor incoming all default
codec g711ulaw
no vad
voice translation-rule 1
rule 1 /3333850/ /3850/
rule 2 /013333850/ /3850/
rule 3 /3333851/ /3851/
rule 4 /013333851/ /3851/
rule 5 /3333852/ /3852/
rule 6 /013333852/ /3852/
voice translation-rule 2
rule 1 /3850/ /013333850/
rule 2 /3852/ /013333852/
rule 3 /380[1-9]/ /013333851/
rule 4 /381[0-5]/ /013333851/
rule 5 /3851/ /013333851/
voice translation-profile IN
translate called 1
voice translation-profile OUT
translate calling 2
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
pri-group timeslots 1-10,16
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
ip address 10.19.0.2 255.255.255.252
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/2
ip address a.b.c.d 255.255.255.224
ip access-group OUTSIDE in
ip nat outside
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn outgoing display-ie
no cdp enable
router rip
version 2
network 10.0.0.0
default-information originate
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 a.b.c.e
ip access-list extended OUTSIDE
deny   tcp any any eq 1720
deny   tcp any any eq 5060
deny   udp any any eq 5060
deny   tcp any any eq 5061
permit ip any any
access-list 1 permit 10.0.0.0 0.255.255.255
tftp-server flash:flash/dkern9951.100609R2-9-1-1SR1.sebn alias dkern9951.100609R2-9-1-1SR1.sebn
tftp-server flash:dkern9951.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9951.9-1-1SR1.sebn
tftp-server flash:rootfs9951.9-1-1SR1.sebn
tftp-server flash:sboot9951.031610R1-9-1-1SR1.sebn
tftp-server flash:sip9951.9-1-1SR1.loads
tftp-server flash:skern9951.022809R2-9-1-1SR1.sebn
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:sip9971.9-1-1SR1.loads
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn
control-plane
voice-port 0/0/0:15
translation-profile incoming IN
mgcp profile default
dial-peer cor custom
name local
name mobile
name intern
dial-peer cor list mobile
member mobile
dial-peer cor list local
member local
dial-peer cor list intern
member intern
dial-peer cor list all
member local
member mobile
member intern
dial-peer cor list loc-mob
member local
member mobile
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
dial-peer voice 200 pots
corlist outgoing local
translation-profile outgoing OUT
destination-pattern 9[2-9]......
port 0/0/0:15
forward-digits 7
dial-peer voice 300 pots
corlist outgoing mobile
destination-pattern 90..........
port 0/0/0:15
forward-digits 11
dial-peer voice 400 pots
corlist outgoing intern
destination-pattern 900T
port 0/0/0:15
prefix 00
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 13
max-dn 30
ip source-address 10.19.0.2 port 2000
system message
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern 3...
web admin system name admin password password
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 3...
create cnf-files version-stamp 7960 Nov 28 2012 18:24:35
ephone-dn  1  dual-line
number 3801
label U1
name U1
corlist incoming loc-mob
ephone-dn  2  dual-line
number 3802
label U2
name Soa U2
ephone-dn  3  dual-line
number 3803
label U3
name U3
ephone-dn  4  dual-line
number 3804
label U4
name U4
ephone-dn  5  dual-line
number 3805
label U5
name U5
ephone-dn  6  dual-line
number 3806
label U6.
name 6U
ephone-dn  7  dual-line
number 3852
label U7
name U7
ephone-dn  8  dual-line
number 3808
label U8
name U8
ephone-dn  9  dual-line
number 3809
label U9
name U9
ephone-dn  10  dual-line
number 3810
label U10
name U10
ephone-dn  11  dual-line
number 3851
label U11
name U11
ephone-dn  12  dual-line
number 3812
label U12
name U12
ephone-dn  13  octo-line
number 3813
label U13
name U13
ephone  1
mac-address D76A.EA99.51BD
type 7911
button  1:1
ephone  2
mac-address D76A.EA99.025E
type 7911
button  1:2
ephone  3
mac-address D76A.EA99.0212
type 7911
button  1:3
ephone  4
mac-address D76A.EA99.8AE8
type 7962
button  1:4
ephone  5
mac-address D76A.EA99.1849
type 7962
button  1:5
ephone  6
mac-address D76A.EA99.1705
type 7962
button  1:6
ephone  7
mac-address D76A.EA99.8AF4
type 7962
button  1:7
ephone  8
mac-address D76A.EA99.54D3
type 7911
button  1:8
ephone  9
mac-address D76A.EA99.4A68
type 7911
button  1:9
ephone  10
mac-address D76A.EA99.50DF
type 7911
button  1:10
ephone  11
mac-address D76A.EA99.50D4
type 7911
button  1:11
ephone  12
mac-address D76A.EA99.50DE
type 7911
button  1:12
ephone  13
mac-address D76A.EA99.A567
button  1:13
1 REPLY
Hi Jacob,
instead of 'dtmf-relay sip-notify', could you please try 'dtmf-relay rtp-nte' under voice register pool 1&2 and let me know how it works?
//Suresh Please rate all the useful posts.
211
