Community Member
Phone Line status
Can I get answer why the line on unregistered phone is still active? In older version of CCM, line could not receive call when the phone is unregistered? What is the purpose new changed approach?
Re: Phone Line status
exactly what are you trying to do??
if a line is binded to a device, the device needs to be active and registered for the line to work.
if you need a line without the need of a device configure a CTI RP
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
If the line is active, even if the phone is unregistered, I will be routed to that line. It is a problem. When the phone and corespondig line is on remote site, I will stil have to configure fild under line "Unregistered internal" (with CSS)and "Unregistered external" (with CSS)and it will be OK only for one location.
Stil, I can not use abbriviated diling form HQ(4 digit preserved srst), because that 4 digit pattern will never be matched for particular phone.
How can I make line inactive when the phone is unregistered?
you already asked this some days ago
you cannot, if the line is configured it's in the DB; if it's in the DB it's in the routing table; if it's in the routing table it's available for digit analysis
on versions without CFUR it simply returned fast busy or was FW to something if it had CFA before it got unregistered.
versions with CFUR will follow that behavior when phone is unregistered
no other options
java
java
Community Member
OK,
But is it helpful?
When I have 3 locations and one is down (in srst). All users, from both locations should go through the same CSS (CFUR or CFA) of unregistered phone, and call will be routed through same gateway, no mater on which active site is caller?
Am I right, or I am missing something?
132
