Phone load & templates for SRST Mode
Any body can help what is wrong with this config. and how I can get auto load from CUCM, I am unable to get phone loaded, please see attached phone regesteration log.
telephony-service
srst mode auto-provision all
srst ephone template 5
srst ephone description srst fallback auto-provision phone  : Feb 10 2012 20:56:40
srst dn template 3
srst dn line-mode dual
max-ephones 30
max-dn 60
ip source-address 10.221.82.15 port 2000
system message Tatweer Petroleum
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Feb 12 2012 07:06:06
ephone-dn-template  3
ephone-template  5
softkeys idle  Newcall Cfwdall Pickup
softkeys seized  Endcall Cfwdall Pickup
softkeys alerting  Endcall
softkeys connected  Endcall Hold Park Trnsfer telephony-service
Ali
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Yes, you need to upgrade IOS to at least 15.1.1T as that is the first version that supported these phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
As to the firmware upgrade after you install the firware on CUCM server, if you do not want to apply it to all phones simply make sure the device defaults page references the old firmware and then manually assign the new one as the load version on a single phone you want to use.
HTH, please rate all useful posts!
Chris
What is the phone type and what are you seeing on the phone?
Chris
Hi Chris
The phone model is 6921, and the message on the phone is "Phone not registered".
I tested with 7945 model and it works, but with the model above dosen't work.
Ali
What version of IOS are you using? This may be bug CSCti24483.
Notice the following error:
StationButtonTemplateReqMessage for unsupported phone-type 495
Here is similar threads:
https://supportforums.cisco.com/message/3537656#3537656
HTH,
Chris
IOS ver 15.0
Any idea how do I upload the firmware on the SRST router, and where to download?
Ali
First I would update the IOS to either 15.1T or 15.1M train.
The I would install latest firmware file for 6921 phone on CUCM.
To download all of the above you need to have valid Cisco contract, for IOS you browse to Support --> Downloads --> IOS and locate your router type
For 6921 firmware you can get it from here:
http://www.cisco.com/cisco/software/release.html?mdfid=282622815&flowid=5289&softwareid=282074289&release=9.2%282%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Chris
Hi Chris,
Do I need to update the IOS?
Can I upload the firmware for one disk phone, could you please give me the procedure.
Chris
674
