Phone Load Vs Phone Firmware
I was taking a look at the new firmware version for the 6921 Phone that I have.
Then I saw that there 2 types of files.
Phone Firmware a zip one and Phone load a sgn one.
What is the diference between Phone Firmware and Phone load?
http://i55.tinypic.com/69qf42.jpg
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Phone Load Vs Phone Firmware
Hi Rafael,
In your example the .zip files are used when CUCM is not
available for use during the Firmware upgrade process. The files
are unzipped and loaded on a TFTP server to upgrade. In most cases
you will be using the .cop files via Software Upgrade on CUCM. These
files may be signed or unsigned so you will want to view the ReadMe
that comes with each release
Cheers!
Rob
1 REPLY
Hi Rafael,
Cheers!
Rob
398
