Phone Lock
Locking of CISCO IP phone to avoid any kind of abuse and avoiding any surprise on the  bill,i have seen thirdy party software imagicle which is
Compatible with in  Cisco Unified Communication.
Is there any way to configure in CUCM without going to a thirdy party software?
  • IP Telephony
Phone Lock
No, out of the box you only get EM, FAC and CMC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Phone Lock
Jaime is right. You should try to take a look here: http://www.2ring.com/NewJuice.
2Ring PHONE SERVICES can help you with your needs. And also have to mention that FREE or TRIAL license is available.
Martin
you can either use extension
you can either use extension mobility feature for the Authentication purpose
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsem.html
or else can use  Client Matter Codes and Forced Authorization Codes for Authentication on basis of route pattern
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/cmfsgd701/fsfaccmc.html
Regards Akhilesh Nambiyath
145
