10-06-2007 07:08 AM - edited 03-15-2019 06:50 AM
hi folks,
i faced a problem while configuring unity connection but now it seems to be working fine i just want update that y it happened.
i did configuration of unity for the first time but i was not able to dial unity pilot number it used to give me fast busy tone.
but now suddenly it started working fine.
any suggestion y this happened.
10-07-2007 11:08 AM
Perhaps your Voicemail Hunt List was not registered, did you restart any services on Callmanager or Unity?
Did you change any Calling Search Spaces/Partitions?
Chris
10-07-2007 10:38 PM
no i didn't start any service but i did restart unity connection server but i think it does not matter as while confguring i didnt touched any of the service on unity.
thx for your reply.
