11-20-2013 11:37 PM - edited 03-16-2019 08:31 PM
Cisco IP Phone 6921 not register while the other IP Phones is working fine
What will be the cause of that problem? And how we can resolve this issue.
11-20-2013 11:48 PM
Hi Joel,
What is the Call Manager version u are using? Are the phones added manually or through Auto-registration?
what is appearing on screen of 6921?
regds,
aman
11-21-2013 12:08 AM
our calling manager version is 3900 and its manually registration , also in the screen it show phone not registered
11-21-2013 12:25 AM
Hi Joel,
Are u using Call Manager Express installed on 3900 series router ?
If yes, can u share the show version and show config of router .
else Call manager is installed on Server.
regds,
aman
11-21-2013 12:46 AM
this is running config
Building configuration...
Current configuration : 64509 bytes
! Last configuration change at 07:06:53 GMT Thu Nov 21 2013 by admin
! NVRAM config last updated at 11:34:14 GMT Thu Nov 21 2013
version 15.3
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname CROMWELL-MDF-VG1
boot-start-marker
boot system flash1:c3900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
card type e1 0 0
logging buffered informational
enable secret 5 $1$rKH3$bD02WffSq4SzgWhhTaU2c1
aaa new-model
aaa authentication login h323 group radius
aaa authorization exec h323 group radius
aaa accounting connection h323 start-stop group radius
aaa session-id common
clock timezone GMT 4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
template 7
crypto pki trustpoint TP-self-signed-2493497184
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2493497184
revocation-check none
rsakeypair TP-self-signed-2493497184
crypto pki trustpoint cme_cert
revocation-check crl
crypto pki certificate chain TP-self-signed-2493497184
certificate self-signed 01
30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343933 34393731 3834301E 170D3131 30333037 31313436
31315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34393334
39373138 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
81009E1E E7DCBBB7 DF03931E C1240AC1 F916FB9C 28A46FBF CBE7189A 4520A192
D5DB4391 DA08A01A A016E719 8264214F F934406F E7547EA6 E51CF17D 0C69094B
9E732029 C9FA0F5E 59567515 F61DF887 838D7E06 DC905069 64BE0072 9357BBE1
DCB98A43 5E353D20 45AB02CF 803A0DAE 1A349C2B 5EC1727F 7EDCF811 5A37598A
DB530203 010001A3 70306E30 0F060355 1D130101 FF040530 030101FF 301B0603
551D1104 14301282 1043524F 4D57454C 4C2D4D44 462D5647 31301F06 03551D23
04183016 80142AFC E97F3025 746C5D74 4F43581B 9BE4E2AB F109301D 0603551D
0E041604 142AFCE9 7F302574 6C5D744F 43581B9B E4E2ABF1 09300D06 092A8648
86F70D01 01040500 03818100 0020DCEF 2655848D BB069E81 D9434559 649DF504
6D1EAAD6 722ED5B1 BCEE47FB 74DFBC3E EABF2577 A24927C0 7ADF1765 05DD9A32
AC20290E 1CC55ED7 71CB4AF4 E0A06BF6 7FABF9C4 D96E25A0 9A3A855D A9768967
ACC2C1AF 3961807F 7A2A5A86 842E3FF4 3F67671A 65F5158B 000D0874 94A35177
AA0D18CD E73481B4 B66C9A26
quit
crypto pki certificate chain cme_cert
voice-card 0
dsp services dspfarm
voice service pots
fax rate disable
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
modem passthrough nse codec g711alaw
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone UAE-CUSTOM-ERICSSON
dualtone disconnect
frequency 425
cadence 325 325
voice class custom-cptone UAE-CUSTOM-SIEMENS
dualtone disconnect
frequency 425
cadence 425 325 250 500
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
frequency 450
cadence 250 250
voice class custom-cptone UAE-CUSTOM-FETEX
dualtone disconnect
frequency 425
cadence 375 375
dualtone disconnect
frequency 425
cadence 325 325
voice register global
application word
voice logout-profile 1
voice lpcor enable
voice translation-rule 1
rule 1 /^5\(4..\)/ /\1/
voice translation-rule 2
rule 2 /\(^4..\)/ /5\1/
oice service pots
fax rate disable
oice service voip
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
dualtone conference
frequency 600 900
dualtone disconnect
frequency 425
cadence 325 325
dualtone disconnect
frequency 425
dualtone disconnect
frequency 450
cadence 250 250
dualtone disconnect
frequency 425
cadence 375 375
dualtone disconnect
frequency 425
cadence 325 325
application word
oice lpcor enable
oice translation-rule 3
rule 3 /^\(.*\)/ /9\1/
oice translation-profile 5Stripping_PSTN_In
translate calling 3
translate called 1
oice translation-profile PSTN_Outgoing
translate calling 2
pplication
package callindss word
package auth param
service app-b-acd-aa
paramspace english index 1
paramspace english language en
paramspace english location falsh:
param service-name app-b-acd
param aa-pilot 444
service app-b-acd
param aa-hunt1 751
param aa-hunt2 4110
param number-of-hunt-grps 4
service queue flash:app-b-acd-2.1.0.0.tcl
icense udi pid C3900-SPE100/K9 sn FOC14264G0E
w-module pvdm 0/0
w-module sm 1
rchive
path flash1:
ile privilege 0
panning-tree portfast bpduguard
panning-tree vlan 14 priority 36576
panning-tree vlan 170 priority 36576
ial-control-mib retain-timer 240
ial-control-mib max-size 300
sername
sername admin privilege 15 password 7 01105717585B575D72
sername word view aaa
edundancy
ontroller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
w-accounting aaa
acct-template customl
w-accounting syslog
nterface Loopback0
no ip address
nterface Embedded-Service-Engine0/0
no ip address
shutdown
nterface GigabitEthernet0/0
description Connects to CROMWELL-MDF-CSW1 Gig 1/23
no ip address
duplex auto
speed auto
nterface GigabitEthernet0/0.14
description L3 Interface for Voice
encapsulation dot1Q 14
ip address 10.25.4.2 255.255.255.0
nterface GigabitEthernet0/0.170
description L3 Interface for MGMT
encapsulation dot1Q 170
ip address 10.25.7.17 255.255.255.192
nterface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
nterface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
nterface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
nterface Integrated-Service-Engine1/0
description Connection To NME-CUE
ip unnumbered GigabitEthernet0/0.14
service-module ip address 10.25.4.3 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.25.4.2
no keepalive
p forward-protocol nd
p http server
p http authentication local
o ip http secure-server
p http timeout-policy idle 60 life 86400 requests 10000
p http path flash:/gui
p route 0.0.0.0 0.0.0.0 10.25.7.1 name CROMWELL-MDF-CSW1
p route 10.25.4.3 255.255.255.255 Integrated-Service-Engine1/0
ogging source-interface Loopback0
ogging host 10.25.9.11
ls resp-timeout 1
pd cr-id 1
ftp-server flash:Desktops/320x212x12/CampusNight.png
ftp-server flash:Desktops/320x212x12/CiscoFountain.png
ftp-server flash:Desktops/320x212x12/MorroRock.png
ftp-server flash:Desktops/320x212x12/NantucketFlowers.png
ftp-server flash:Desktops/320x212x12/TN-CampusNight.png
ftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
ftp-server flash:Desktops/320x212x12/TN-Fountain.png
ftp-server flash:Desktops/320x212x12/TN-MorroRock.png
ftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
ftp-server flash:Desktops/320x212x12/Fountain.png
ftp-server flash:Desktops/320x212x12/CiscoLogo.png
ftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
ftp-server flash:ringtones/Analog1.raw
ftp-server flash:ringtones/Analog2.raw
ftp-server flash:ringtones/AreYouThere.raw
ftp-server flash:ringtones/AreYouThereF.raw
ftp-server flash:ringtones/Bass.raw
ftp-server flash:ringtones/CallBack.raw
ftp-server flash:ringtones/Chime.raw
ftp-server flash:ringtones/Classic1.raw
ftp-server flash:ringtones/Classic2.raw
ftp-server flash:ringtones/ClockShop.raw
ftp-server flash:ringtones/DistinctiveRingList.xml
ftp-server flash:ringtones/Drums1.raw
ftp-server flash:ringtones/Drums2.raw
ftp-server flash:ringtones/FilmScore.raw
ftp-server flash:ringtones/HarpSynth.raw
ftp-server flash:ringtones/Jamaica.raw
ftp-server flash:ringtones/KotoEffect.raw
ftp-server flash:ringtones/MusicBox.raw
ftp-server flash:ringtones/Piano1.raw
ftp-server flash:ringtones/Piano2.raw
ftp-server flash:ringtones/Pop.raw
ftp-server flash:ringtones/Pulse1.raw
ftp-server flash:ringtones/Ring1.raw
ftp-server flash:ringtones/Ring2.raw
ftp-server flash:ringtones/Ring3.raw
ftp-server flash:ringtones/Ring4.raw
ftp-server flash:ringtones/Ring5.raw
ftp-server flash:ringtones/Ring6.raw
ftp-server flash:ringtones/Ring7.raw
ftp-server flash:ringtones/RingList.xml
ftp-server flash:ringtones/Sax1.raw
ftp-server flash:ringtones/Sax2.raw
ftp-server flash:ringtones/Vibe.raw
ftp-server flash:Desktops/320x212x16/List.xml
ftp-server flash:Desktops/320x212x12/Cromwell.png
ftp-server flash:Desktops/320x212x12/TN-Cromwell.png
ftp-server flash:cmterm-6901_6911-sccp.9-2-2-5.cop.sgn
ftp-server flash:SCCP6901.9-0-2-0.loads
ftp-server flash:ATA030204SCCP090202A.zup
ftp-server flash:atapost.pl
ftp-server flash:atapost_readme.txt
ftp-server flash:ata_03_02_04_sccp_090202_a_contents.txt
ftp-server flash:AudioCfg.htm
ftp-server flash:bitaid.exe
ftp-server flash:bitaid.txt
ftp-server flash:cfgfmt.exe
ftp-server flash:cfgfmt.linux
ftp-server flash:cfgfmt.sun
ftp-server flash:cfgfmt.txt
ftp-server flash:DebugCfg.htm
ftp-server flash:NetCfg.htm
ftp-server flash:prserv.exe
ftp-server flash:prserv.linux
ftp-server flash:prserv.sun
ftp-server flash:prserv.txt
ftp-server flash:ptag.dat
ftp-server flash:release_notes.txt
ftp-server flash:sata186us.exe
ftp-server flash:sata186us.linux
ftp-server flash:sata186us.sun
ftp-server flash:sata186us.txt
ftp-server flash:SCCPCfg.htm
ftp-server flash:ServiceCfg.htm
ftp-server flash:sk_example.txt
ftp-server flash:ToneCfg.htm
ftp-server flash:transition.zup
ftp-server flash:UPGRADE_NOTICE.txt
ftp-server flash:zupinfo.exe
ftp-server flash:zupinfo.txt
ftp-server flash:APP6901SCCP.9-2-1-a.zz.sgn
ftp-server flash:APP6911SCCP.9-2-1-a.zz.sgn
ftp-server flash:BFS6911SCCP.9-2-1-a.zz.sgn
ftp-server flash:KNL6901SCCP.9-2-1-a.zz.sgn
ftp-server flash:KNL6911SCCP.9-2-1-a.zz.sgn
ftp-server flash:SCCP6901.9-2-1-a.loads
ftp-server flash:SCCP6911.9-2-1-a.loads
ftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
ftp-server flash:DSP69xx.0-0-0-8.zz.sgn
ftp-server flash:SCCP69xx.9-2-1-0.loads
ftp-server flash:SCCP69xx.9-2-1-0.zz.sgn
ftp-server flash:its/vrf1/XMLDefault6901.cnf.xml
ftp-server flash:its/vrf1/XMLDefault6911.cnf.xml
ftp-server flash:its/vrf1/XMLDefault7926.cnf.xml
ftp-server flash:its/vrf1/XMLDefault6945.cnf.xml
ftp-server flash:its/vrf1/XMLDefault8941.cnf.xml
ftp-server flash:its/vrf1/XMLDefault8945.cnf.xml]
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:B016-1-0-4.SBN
tftp-server creddentials
access-list 23 permit 10.10.10.0 0.0.0.7
radius-server host 10.25.9.11 auth-port 1612 acct-port 1616
radius-server key 7 04585A150C711D1C5A
control-plane
voice-port 0/0/0:15
local-alerting
voice-port 0/1/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-ALCATEL
supervisory dualtone-detect-params 1
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 50
connection plar 0
impedance complex2
caller-id enable
caller-id alerting line-reversal
voice-port 0/1/1
cptone GB
connection plar 0
impedance complex2
caller-id enable
voice-port 0/1/2
cptone GB
connection plar 0
impedance complex2
caller-id enable
voice-port 0/1/3
cptone GB
connection plar 0
impedance complex2
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.14
sccp ccm 10.25.4.2 identifier 100 version 7.0
sccp
sccp ccm group 123
bind interface GigabitEthernet0/0.14
sccp ccm group 1
associate ccm 100 priority 1
associate profile 1 register confdsp1
dspfarm profile 1 conference
codec g711ulaw
maximum conference-participants 32
maximum sessions 1
conference-join custom-cptone jointone
associate application SCCP tftp-server flash:cnu45.9-2-1TH1-13.sbn
control-plane
voice-port 0/0/0:15
local-alerting
voice-port 0/1/0
cptone GB
connection plar 0
impedance complex2
caller-id enable
voice-port 0/1/1
cptone GB
connection plar 0
impedance complex2
caller-id enable
voice-port 0/1/2
cptone GB
connection plar 0
impedance complex2
caller-id enable
voice-port 0/1/3
cptone GB
connection plar 0
impedance complex2
caller-id enable
sccp
sccp ccm group 123
sccp ccm group 1
codec g711ulaw
maximum sessions 1
11-21-2013 01:48 AM
Hi Joel,
what I can see you do not have the firmware version for 6921 model?
regds,
aman
11-21-2013 02:04 AM
here its
tftp-server flash:APP6901SCCP.9-2-1-a.zz.sgn
tftp-server flash:APP6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:BFS6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:KNL6901SCCP.9-2-1-a.zz.sgn
tftp-server flash:KNL6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:SCCP6901.9-2-1-a.loads
tftp-server flash:SCCP6911.9-2-1-a.loads
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-8.zz.sgn
tftp-server flash:SCCP69xx.9-2-1-0.loads
tftp-server flash:SCCP69xx.9-2-1-0.zz.sgn tftp-server flash:APP6901SCCP.9-2-1-a.zz.sgn
load 6921 SCCP69xx.9-2-1-0
am i correct
11-21-2013 02:30 AM
Hi Joel,
you are correct.I have checked in 6921 firmware under download and is available.
What is CME version u are using to check for any compatibility issues ?
regds,
aman
11-21-2013 03:20 AM
hi aman
the firmware is already uploaded and i dont have problem with the firmware because some of the 6921 phones is working fine but not listed on the CME.
How can i check if i already exceeded the limit of connection. where my maximum limit is 265 and i still used 180 connections.
CME version is 8.5
11-21-2013 04:40 AM
Hi Joel,
No idea .
I think u have already opened another discussion.
the number of IP phones supported would depend on Router model.you can refer the link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
regds,
aman
11-21-2013 04:52 AM
Hi aman,
Thanks for the info...
CISCO 3925 this is our router. And I didnt reach the maximum limit yet because its still 190 Ip Phone connected to this router.
And I cant add another Ip Phone to my CME
Sorry I open a new discussion because I really need help,
11-21-2013 05:33 AM
Hi Joel,
There is nothing to say Sorry.
It is good if other members can see and advise .
regds,
aman
11-21-2013 05:34 AM
Hi Joel,
Just refer this link if it helps.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.html#wp1054191
regds,
aman
11-21-2013 07:10 AM
Hi Joel,
Can u cross-check what u have configured for max-ephones which to be supported ?
regds,
aman
11-21-2013 08:32 AM
Kindly see the config details.
max-ephones 265
max-dn 600
service dnis dir-lookup
timeouts interdigit 5
timeouts ringing 45
cnf-file location flash:
cnf-file perphone
load 7916-24 B016-1-0-3.sbn
load 7945 SCCP45.9-2-1S
load 7965 SCCP45.9-2-1S
load 6941 SCCP6901.9-0-2-0.loads
load 6901 SCCP6901.9-2-1-a
