Phone Proxy with UCM 9.X
The SRND states:
"Cisco Unified CM 9.x currently does not support the ASA Phone Proxy and TLS Proxy features."
Does anyone know if this is going to be supported in the future, if not what is the alternative solution?
Thanks in advance
Stewart
Everyone's tags (6)
Phone proxy is being moved to CUBE (The last I heard was that not all phone features are currently supported)
GTG
Please rate all helpful posts.
Or you can use the phone built-in VPN feature, all discussed in the CUCM security guide on CCO
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
101
