Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Phone proxy
What's ASA phone proxy solution for remote phone across the internet?
Re: Phone proxy
It allows you to establish secure connection between phone and ASA - which is working like proxy for your calls and communication with CM. You don't need any VPN tunnels, so it's useful for homeworkers or teleworkers.
Check this link for more information: http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns165/ns391/at_a_glance_C45-500231_v1.pdf
rate if this help
Re: Phone proxy
Works well for us, but currently the licensing costs are is crazy if you want fail-over. Soon to be sorted apparently, according to our SE.
We use mainly for our 7921 phones, plus a few home workers, and testing CUMA at present with iPhones. In total ~40 handsets
Cheers,
Alistair
Re: Phone proxy
How about your home user's ip phone?I am thinking of CP-7942G and CIPC. Can use ASA free two uc proxy licens to test?
Re: Phone proxy
Should be OK for the 7942, but CIPC is NOT yet compatible with Phone proxy.
Crazy I know, but I have heard it should be supported early next year.
Cheers,
Alistair
572
