Phone "stuck" after end call
When our customer uses the phone and make a call then put the phone on-hook, the connection is not "disconnected", the phone seems stuck, pressing the end call is not anything occurs, only way is reseting the phone by removing the cable network. Found our QoS (because it is a remote site where the callmanager are) and that seems ok with the QoS(signaling)
We using ccm 4.1
Guilherme Henrique Villarinho www.avvid.net
1 REPLY
Hall of Fame Super Gold
Re: Phone "stuck" after end call
Which phone model and which FW on it ? Can be seen with device info from phone menu.
Also specify CCM patchlevel.
127
