Community Member
Phone registers but will not pull specific load
I have a phone that is registering with my CM but will not pull specific configuration file for the phone.. I.E. will not pull button configs or DN.
Basic Setup..
    Static IP on phone
    Voice VLAN
    IP Routing in place (0.0.0.0 xxx.xxx.xxx.xxx) generic route to point everything to next hop
Phone shows:      CTL Installed
                          SEP(MAC).cnf installed
CM Shows phone resigered
From what I can see the phone is configured correctly (was tested in a serperate location and registered correctly and was able to place test call with no issues) and CM is good.
What should I look for in the network?
Everyone's tags (3)
1 REPLY
Re:Phone registers but will not pull specific load
Try deleting the CTL file on the phone.
HTH Regards, Yosh
239
