Phone registration
I have ccm 7.0 to install.
It is a single cluster over the wan. There are 3 sites and each site will have its own subscriber. I want the phones at each site to register with the relevant site subscriber and use the local server as the call processor.
I understand that i will need to create ccm groups, and that the phones get a list of CUCM's from the tftp server xml file.
But how does the xml file get created? how does it know the right subscriber for each site?
2 ACCEPTED SOLUTIONS
Re: Phone registration
that's not possible without you doing some config
autoregistered devices use the default device pool you configured. ALL DEVICES USE THE SAME DEVICE POOL. thus the same CUCM group
once they register you need to change the Device pool manually
java
if this helps, please rate
java
www.cisco.com/go/pdi
Silver
After creating the CCM-Groups, I would continuing by creating 3 different Device Pools(DP), one for each site and select the appropriate DP in the phone configuration page.
MK
the files get created automatically, you don't even need to worry about that. just configure using CCMadmin
java
java
many thanks for the feedback, but i don't understand how a phone will know which is the primary server to register to?
If I have a subscriber at each site (3 sites) I want to have the phone register to the relevant server for that site.
I have 3 dhcp scopes setup on the database.
If I then setup 3 ccmgroups and 3 device pools.
each CCM sub is setup for auto register
How can you determine that each phone will auto register with the correct CCM sub.
Silver
Let's say you create 3 CallManage groups(CCMGrpA, CCMGrpB, CCMGrpC) and 3 Device Pools( DP1, DP2, DP3). In the CallManager group configuration page, from the "Available Cisco Unified CallManagers" you select the right CCM-Sub and drop it into the "Selected Cisco Unified CallManagers". Then in the Device Pool configuration page, select the right CCMGrp, let's say you select the CCMGrpA for the DP1. In the phone configuration page from the Device Pool drop down menu you select the DP1. The configured phone will register with CCMgrpA which has the IP address/Name of the desired CCM-Sub.
MK
Apologies if I am not explaining very clearly, I understand the config you mentioned. That is for phones that have already registered, I want the devices to auto register with the correct server.
In other words before any devices are registered
java
java
189
