Phone registration
We have problem with registering cisco 6921 phone to CUCM 8.6.
We have about 400 phones and most of them are working fine, but some of them not registering.
They get ip address from DHCP, I can see phones as CDP neighbors but I cannot reach them. Ping doesn't work.
I tried to plug another phone in same switch port and it worked. Do you have any ideas?
Hi,Have you tried a Factory
Have you tried a Factory Reset on the effected phones?
Step 1 Unplug the power cable from the phone and then plug it back in.
The phone begins its power-up cycle.
Step 2 While the phone is powering up, and before the Speaker button flashes on and off,
press and hold #.
Continue to hold # until each line button flashes on and off in sequence in amber.
Step 3 Release # and press 123456789*0#.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/6921_6941_6961/7_1_2/english/admin/guide/69214161AG/6921trb.html#wp1031705
Richard
This factory reset doen't
This factory reset doen't work on 6921 phones...
I tried reset all setting from applications menu, but still the same problem...
Hi 1- For reset factory ,
1- For reset factory , check the below:-
https://supportforums.cisco.com/discussion/11436876/69216941-factory-reset
2-Did you erase the CTL & ITL from device physically - setting-**# - security setting - ctl & itl erase.
3- Can you chech the firmware of 6921 which unable o register ?.
please rate all useful information
Hi,1. Factory reset doesn't
1. Factory reset doesn't work on 6921, I had tried it before...
2. I erased CTL & ITL.
3. firmware is SCCP69xx.9-3-1-3
Are there enough IP address
Are there enough IP address available in the DHCP scope, can you verify the phone is getting an IP from the correct DHCP server and validate the settings show the same on the phone menu?
As a known working phone can be connected to the same switchport and work we can rule out issues with the switchport configuration but the phone will be maintaining its DHCP lease.
HiI've already checked DHCP.1
1. IP addresses are available in DHCP scope.
2. Phone gets IP address from valid dhcp server, and when I checked on server and on phone, both addresses are same.
Just to confirm you can ping
Just to confirm you can ping a working phone but you can't ping a none working phone?
Yes, that's right. I can ping
Yes, that's right. I can ping working phone but can't ping none working phone.
When you connect the working
When you connect the working phone are you using the same ethernet cable or do you also change that? If you haven't already try a different - known working - ethernet cable
I use same cable, seems like
I use same cable, seems like hardware fault...
It could be a hardware fault,
It could be a hardware fault, might be a dodgy batch.
You could also try configuring the IP Address, Subnet Mask, Default Gateway and TFTP Server manually on the phone to see if you can then ping it and if it will then register to CUCM
I've already tried it but no
I've already tried it but no success. still same problem
Do you definitely have the
Do you definitely have the right default router/gateway set - I have seen it before that when this is incorrect you are unable to connect to the phone.
Richarddefault gateway is
Richard
default gateway is correct - as other network configuration...
hardware faultor firmware
hardware fault
or firmware bug
I had  firmware bug 9.1.1.0
Other working phones have
Other working phones have same firmware, so it looks like hardware fault...
thank you.
check firmware. probably you
check firmware. probably you need latest.
actually it is not the
actually it is not the problem between cisco 6921 phone and CUCM 8.6.
if you can not ping 6921 phone from L3 switch so it is problem in IP or DHCP level or in VLANs or in subnets
thanks for reply,When I
thanks for reply,
When I connect another phone to same switch port it works fine, so its not Vlan and dhcp problem...
Hello1- Kindly do a factory
Hello
1- Kindly do a factory reset for your phones which have problem.
if problem still exist
1- make sure that your IP phones one the correct voice vlan , check your L3 , check your intervlan configuration
if the problem still exist
1-go to phone physcially - setting - security setting - erase CTL & ITL .
1-try to connect one of the Ip phones which is registered properly before to the switch port which connected to ip phone which unable to register .
74
