Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Phone remains ringing when using FXO ports
When there is an incoming call from PSTN that goes through an analog trunk (FXO) and nobody answer, if the calling party hang up the called party's phone remains ringing.
How can I set a time in order to avoid the called party's remaining ringing???
I set the next config in the port but it does not work.
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 500
regards
Hall of Fame Super Gold
Re: Phone remains ringing when using FXO ports
Which exact IOS are you running ?
Hi, thanks for your interest in this issue.
sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3h), RE
LEASE SOFTWARE (fc2)
Technical Support:
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-spservicesk9-mz.124-3h.bin"
If this router is not in the US you will want to enter your CPtone. Otherwise, the 'supervisory disconnect dualtone' will be looking for the wrong frequencies.
By the way - you have a larger problem than phones ringing. Try this - take a phone call from the PSTN, and transfer it out back to the PSTN out the same router. Now disconnect both calls. I'm fairly certain both ports will be stuck in a connected state indefinitely because your FXO disconnection isn't working properly.
hth,
nick
119
